P10 Cleanwave
Hi,
Quick question to make sure, but is there any issue in running the Cleanwave on the P10 with a component with a hard drive powered by the P10? I just connected my Roon Rock to the P10 and want to make sure.
Thanks in advance!
I’ve got a Melco (2x build-in internal ultra high grade SSD + 1 external 2,5 drive) hooked up to my P10. Often using the Cleanwave and never had issues. Good question, incidentally, I never thought about before…
Awesome, thanks! I was kind of unsure, but if you have been alright, I think it will be fine.
Best regards,
Veneet
wijber said Often using the Cleanwave and never had issues. Good question, incidentally, I never thought about before...
I also had no considered this issue. A very good question.
I have a few things connected with hard drives and have had no issues either.
Shouldn’t be a problem.
