Would VTL mb450 monoblocks benefit from being plugged into power regenerator such as P10?
How about Krell ksa200s?
thanks
thanks
Sure. While the MB-450 incorporates impressive power regulation, the better the power input the better the sound.
What prompts you to ask?
I was deciding between the p5, not plugging in the VTLs, and the p10.
Get the P10. It sounds better than the P5 on everything and you can plug in the amp.
