wow, I used a P12 for months and never even suspected there were fans in it! Never came on in my set up. LOL
I have an older P5 in my system and I’m with kylemillsap, the fans have never even turned on except right at start up. I’m only using about 18% of the load though. Reach out to me directly at jamesh@psaudio.com and we’ll get you fixed up.
Ok, so, here’s an update on the Toslink situation:
I just went and purchased the cheapest Toslink ever and while playing with it noticed, that it actually works but only if you insert it just a little bit - just placing the connector there without the click!
If I insert the connector till the end with the conventional click it’s not working - the DAC doesn’t see the signal. I mentioned this also to jamesh via direct email. Maybe that could also be fixed somehow
For those interested, Sergey’s optical is now working well! This is the solution that did the trick.
Just above the Toslink connection is a screw. That screw can be backed out some and then with the cable in place, adjusted until the connection is secure.
Yep! Thanks, jamesh!
Was just about to report that!
I loosened the screw a little to kind of release the plastic socket’s tension (or maybe it’s the distance between the socket and something inside the DAC matters)… anyways, now it works perfectly!
Happens!
I’ve heard someone bought a new pair of speakers and one of the drivers failed. So the manufacturer sent that guy a new driver with instructions and he replaced it by himself.
So, maybe I could replace those fans too!? Send me over the kit!
No, replacing the fans in a power plant is not a straight forward job (that is, if the layout in P12 is similar to P5). The fans are mounted of the chassis bottom, and the guts of just about everything else sit on top of the fans. It can be done, but the point is, for whatever reason, everything was perfect the day it shipped from the factory, and now it’s not. Problem belong with your dealer to fix.
… everything?
I’m also not entirely happy with it’s built. DAC is fine, but P12 has this weird gap between the front panel and it’s right (our left) corner.
Here are some comparisons pictures:
And about “everything”. Everything is mostly the regenerator board that contains the transistors and heat sinks and other bits and pieces, and all this sits on top of the fans. So to get to the fans you must first remove the chassis cover, and then remove the regenerator board.
I think your dealer needs to be involved, to reassemble the chassis corners so they are square, and replace the fans…or maybe they’ll find a ribbon cable that is mis-routed and is brushing against the fan blades. It’s happened before. None of these are new problems.
Cool, thanks, Brodric! I’ll mention that in our further correspondence!
It’s come along way to get to you. It was perfect when it left the factory (and so was the DS DAC). Shipping PS Audio stuff long distances can cause all sorts of problems to appear by the time the customer receives it in far-off 240V lands. Which many here can attest to.
The chassis has four zinc corner pieces, each with four small screws, that connect the side panels, front panel, and back panel. They don’t use a jig to assemble the chassis, it is assembled by hand. Sometimes the corners are not quite square when assembled, resulting in uneven gaps in the joints. Other owners have mentioned this previously in the forum here (it has happened to me also, but in a DSJ). The fix is to undo the bolts, re-adjust the alignment to square, and then tighten it up again.
Україна I am from Kyiv. Please do not mention Nazi’s! I am Jewish!
I have opposite problem. Hardly any load on p12 but fans keep going! it is 81 degrees F in here though.
I wonder what the control logic is for cycling on/off the fans.
yeah, when fans cooled the unit it gets pretty cool, so 81F makes total sense. Do you hear your fans making any sound?
Yeah they make a little noise. Can’t hear it 2’ away. Can’t hear in here anyways. I imagine they are variable speed. Obviously with ambient temp sensor. AC is on 76 but it is 81 in here because there are 3 mini supercomputers in here. They have AC too but it is exhausting into the room! You might ask what the heck is a stereo doing there? This is my third system. I listen while I am working. Yes, I am an Attorney but I found plenty of money to be made rendering. Many days I do not have trial. I just did not want you folks to think I am an idiot so I explained it.
…I’d rather have those spinning constantly instead of hot PP.
Today’s measure showed slightly above 55°C
I was actually unpleasantly surprised to see any fans there at P12. The distributor was very sure there are no fans in power plants. I even called PS Audio before ordering to check about those fans and got the answer that all power plants are fan-less (at least that’s what I remember from that conversation). And I couldn’t find any pictures with the open lid except for those here:
https://www.groovehifi.com/product/ps-audio-directstream-power-plant-p12/
but I didn’t see any fans here or mentions of them. I’d never buy anything with fans to my listening environment! I feel tricked! :-\
And now I have to repair a brand new super expensive (at least for me) device with all shipping expenses and nerves, time, feelings… I am so unlucky!
P12 looks similar to P3, which has fans beneath the heatsinks. Hard to see, but they are there. Perhaps P12 does not have them. I know in Ukraine you have mains sockets that can accept plugs in any polarity - they go either way. Any way you could check that your hot (Live L) wire is coming the right way into the P12. I think it is important. May be not related, just a guess.
thanks, nordic.
Say, I have a way to check via the tester, where I should see the light? in L or “N”?
I just checked and I see the light in “N”. Should I try and turn the plug the opposite side then?
If you have a mains tester with an indicator, like a screwdriver with a bulb inside, the Live should be in the L. This type of plug is called C13, they all are wired the same way. However, the other end which plugs into the wall in Ukraine and many other countries have no strict wiring (except Earth E connection) - Live can be in any pin and plug can be reversed. So if your tester lits up in N (neutral), need to reverse the plug in the wall.
Mains are lethal, if not sure, do not do this.
