P20 tripping 6.3A slow burn Swiss Dig Fuse box
My new SDFB is tripping when my P20 powers up or when it does not trip it will when turn on my Diablo 300.
I have emailed Marc but thought I would ask others here what their experience is with this combo.
Just a guess but the startup time and current draw of the P20 to charge its capacitors might exceed the SDFB. One of the main feature of the PS Audio power plants is that they handle to short power demand surges. Would think that obviates the need to be concerned about the P20 fuse being a currant limiter. And the key advantage of that simple little sacrificial fuse is that it is just about idiot proof as a protection device.
Yeah I am not worried if I return it but I know others have used. Wondering what’s going on there. I put my M1 back in for now
I think the issue here is that the fuse is only for the control electronics. The main power path is protected by a breaker. The current passing through the SDFB can easily exceed the 6.3A rating that you chose, especially at start up if you have big amps
I don’t even know what a SDFB is, but I wanted to chime in because your experience with the PS Audio P20 sounds incredibly familiar. I owned a P20 until recently and ran into very similar electrical headaches.
When I first hooked up my Aurender N10 network hub (which draws very little continuous power), the P20 instantly blew the N10’s fuse the exact millisecond I switched it on. It did it twice. On top of that, when I tried running my Aurender AP20 all-in-one amp through it, the P20 couldn’t handle the reactive ‘power factor’ load. The P20 would heat up like a furnace until it eventually tripped itself into thermal protection mode.
From what I understand, our issues are likely caused by the exact same thing: the way the P20 dumps power. Because the P20 regenerates a mathematically ‘perfect’ AC sine wave with virtually zero impedance, it allows connected gear to draw an incredibly violent instantaneous inrush current spike at startup.
In my case, that split-second spike was enough to instantly vaporize a standard physical fuse twice. In your case, because your SDFB relies on ultra-precise digital monitoring rather than a piece of wire, it is detecting that exact same massive startup spike from the P20/Diablo and instantly tripping its digital relay to protect the circuit.
These power regenerators handle massive energy dumps in ways that easily shock or overwhelm standard fuses and digital breakers alike. You likely need Vera-Fi to program a much more relaxed, delayed ‘slow-blow’ time curve into your SDFB to let that initial spike pass!"
Disclosure: The above is an AI response after I fed it your post; plus my experience.
Perhaps I missed it, but are you using the high current zone?
(The Swiss Digital Fuse Box (SDFB) by Vera-Fi Audio)
I was just about to ask the same question. My P-20 is powered by the High Current version, I have zero issues.
I have spoken with Marc at Verifi and just like some fuses they it needs a higher threshold. He said other customers have used 8amp in his devices. They are swapping out.
Interesting. My SDFB Max works fine at stock 6.3A, as did my regular SDFB before it.
Yeah not sure why mine pops. sometimes with just the P20 powering up and sometimes when the Gryphon powers on. Sometimes NOT.
Turns out Fox was simple. As things changed in system I never set the delays for all the things plugged in P20. Some simple delays for the Diablo dac and subs and all is well.
Great news!
Well I spoke too soon. It popped again after the boot. Turned on Diablo and it went. No idea what’s going on.
Bum. It’s too bad Mark is so ill, he might be able to add some advice.
he is contacting me and trying to help, but like you said his health slows him. I am being patient. its not that important and I told him take his time.
I hope Mark finds someone to keep the company running while he recouperates.
They offer a lot of quality products at affordable prices, hate to see the company fold.
I ordered some of their isolation pucks to try on my speakers. They didn’t work out for my speakers but when I tried them on some of my gear I was blown away by the improvement they brought.
