P5 - how to find active software version
#1
P5… Where can I find software version?
p5 PWT and dsd dac … Screen shows lighter bars traveling bottom to top. They are lighter than display but don’t seem to affect anything, including visibility. Is that normal?
thanks.
#2
The scrolling bars are not normal, but which item has the issue, all three? If so, wow! I had a similar issue with my DS, a firmware update did not solve this for me. Required sending it back to PS Audio for replacement of the screen and driver board.
As for firmware update, go to “Support” then “Downloads”, you’ll find latest version there.
#3
I have the same thing - horizontal waves an inch or so wide moving bottom to the top of the PWT screen. I thought that was normal. Did you take it further woodburger?
My Directstream is fine.
