PC, Pink Faun I2S bridge, PWD Native mode
Hi guys, I know it is old story, but I have connected new Pink Faun I2S bridge to PWD latest firmware, excellent sound quality, but Native and NativeX mode don´t work. When I play different files in resolution I must choose this sample rate manualy…
Is there any solution?
I found this in history topics, but no answer! Perhaps I readed wrong… :
Wijnand wrote:
It looks that there is a problem with the I2S inputs of the PWD.
When I set the I2S input of the PWD in nativeX and try test tones on different samplerates fromout audio output in the configuration screen.
NativeX (in all cases it does show the right samplerate under NativeX in the display)
44.1Khz 16bit, 24bit, 32 bit no sound relais do click.
48KHz 16bit, 24bit, 32 bit no sound relais do click.
88Khz 16bit, 24bit, 32 bit no sound relais do click.
96Khz 16bit, 24bit, 32 bit no sound relais do click.
176Khz 16bit, 24bit, 32 bit all playing fine!
192Khz 16bit, 24bit, 32 bit all playing fine!
Native (in all cases it does show the right samplerate under Native in the display)
88Khz 16bit, 24bit, 32 bit all play fine!
96Khz 16bit, 24bit, 32 bit all play fine!
176Khz 16bit, 24bit, 32 bit all play fine!
192Khz 16bit, 24bit, 32 bit all play fine!
Samplerates chosen by hand.
All test tones play fine!
Tested 3 firmwares. 2.0.2, 2.2.0, 2.4.3
Does anyone have experience with this issue with other equipment?
Nobody tried I2S connection to PWD…?
This is the best SQ of all possibilities, much more better than USB.
Only when I am playing 44,1 and 48 kHz, I must switch off Native mode to these frequencies.
NativeX can play 176 and 192kHz only… Chinese Holo Audio Spring, I tested it two weeks ago,
plays everything fine and with excellent SQ too. Maybe it is time to change thinking of china products(?)
