Perfectwave Directstream DAC - Is it genuine?
Hello,
I recently bought a used Perfectwave Directstream DAC. It has the Sunlight firmware, but when I connect it with my Macbook it doesn’t have the option PS Audio PerfectWave DSD, but only PS Audio USB Audio 2.0 and nothing else.
Serial number is PWS-A1-7D107391 according to the sticker and it says Directstream on the front faceplate.
Yes that is a Directstream mk1.
Thank you. Any suggestion about Mac settings? I used another Directstream in the past and Mac found it immediately.
