I’ve borrowed a PMG DAC 512. The streamer worked brilliantly, but unfortunately only for an hour. After that, it somehow froze and hasn’t booted up since. Switching everything off and restarting the DAC didn’t help, and I’ve also tried updating the firmware of the DAC. I can’t update the streamer’s firmware because it won’t boot up. Does anyone know how I can get the streamer working again?
Either check the streamer firmware (should start up the streamer if powered off) or go into Audio Settings and make sure the streamer is listed as on in the “Input Power” section.
Thanks! When I try to check the streamer’s firmware, it says ‘Streamer Initializing’. I think that means it’s booting up. It just doesn’t stop.
Try unplugging the PMG512. Let it stay unplugged for a full 5 minutes. Then plug back in and try again.
I switched off the DAC and the router, waited 10 minutes and switched them back on. The router recognises the streamer, an IP address is assigned, but the icon of the streamer remains grey and I can’t find the streamer in Roon. I’ll have to contact the seller tomorrow.
Thank you both.
I would email PSAudio service,
I still would try UNPLUGGING. If that doesn’t work, then contact seller. Computers can be finicky sometimes.
I had these same symptoms with my PMG 512 DAC and tried the same things you have. After quite a bit of troubleshooting with the streamer’s software developer, he had me return it to PS Audio. The service folks determined the problem to be a corrupted SD card, which they replaced with a newer, more capacious one and brought my streamer back to life.
— Chris
Thank you very much! I’ve read about your problem and it really reminded me of my own. If it’s just an SD card, the retailer will surely be able to replace it themselves. I’m glad to hear that, because I really love the DAC and definitely want to keep it.
Best regards,
Roger
Best of luck! I feel the same about my DAC.
— Chris
So much easier to pack up the PMG512 and bring it somewhere or pack it up to send it back than trying to unplug the PMG512 and seeing if that works.
Unplugging the power cord and toggling the main power switch off are equivalent functions from the perspective of the DAC. It wouldn’t hurt to try both, but to do so seems redundant.
— Chris
Turning off versus fully unplugging are NOT equivalent. Every once in a while (a total of 2 occasions) I needed to unplug my MU2 to properly reset it. Turning the MU2 off didn’t do the trick.
When I had the M1200’s there was an occasional issue where a relay was stuck in the on position. The ONLY way to reset that was to fully unplug the M1200 on the rare occasion it acted up.
Hmmm. Perhaps your power switch is defective, or what you were toggling was the MU2’s stand-by switch. The PMG 512 has one of those, too, on the front panel, and a power switch on the back.
— Chris
No question unplugging power cord is the only way to ensure no electric flow is going into the unit, and I believe it is the best and only way to truly reboot. I have experienced many times with a number of PSA DACs when trying to update their FWs in the past. Unplugging made it work while turning off switch did not. Recently after a vacation I needed to unplug all power sources from modem, router, and MU2 to find Roon core again. Turning off power switches alone did nothing for me either.
Going back to watch 49ers on 4k, good thing they are leading. ![]()
Whatever seems to work best for you is what you should do, of course. Peace, brothers.
— Chris
Nice!! Very nice!!!
I unplugged the DAC overnight, but the result is still the same. Hopefully changing the SD card will sort it out.
Thank you all.
A little research on my part (Google Gemini, truthfully) indicates that, unlike a true, simple, circuit-cutting on/off power switch, the white “power” button on the MU2 isn’t actually a power switch, being more akin to a stand-by/boot-up toggle. As @adifferentpaul and @dchang05 strenuously purport, the only way to remove power from that device is, in hospital parlance, to “pull the plug”.
In contrast, the power switch on the rear of the PMG Signature 512 DAC is just what it appears to be, and toggling it to the off position provides its owner a more refined way to remove power than unplugging it like a coffee maker. Or a Grimm MU2.
Come to think of it, my coffee maker has a power switch, too, though it doesn’t have a stand-by mode. Some do, I think, in addition to a power switch.
I suppose Eelco and his band of engineers felt that a power switch would introduce unfilterable noise or infuse the sound with some other detrimental quality. I can only speculate, though I am certain it wasn’t a cost-cutting measure.
I continue to remain completely unconvinced that removing power via a(n actual) non-defective power switch or through yanking the plug aren’t equivalent, unless you have one of the rare, expensive, and as-yet-uninvented quantum-tunneling power switches on your gear.
— Chris
I know, it doesn’t make sense, yet there are a multitude of examples that Gemini hasn’t considered (go figure!). For instance, it is a well documented fix on a some ITX ASUS motherboard that when the Bluetooth stops functioning under certain circumstances and the only way to resolve it is to shut off the PC power supply AND unplug it for 2-5 minutes. User reports state that this has been the only way to reset the connectivity issue. Being skeptical, I have tried over and over to just turn off the power supply, sometimes for hours, (using that very familiar IEC inlet power switch that is found on the back of a lot of HiFi gear). No luck, but when unplugging for a few minutes the connectivity comes back.
Perhaps with computers (like the streamer in the PMG DAC) disconnecting the positive lead isn’t enough. I SPECULATE that disconnecting the negative lead (as in unplugging) drains the stored energy in the logic circuits of the Bluetooth and resets it somehow. Couldn’t this be a possible explanation for a streamer circuit as well?
I know that testimonial evidence is often suspect, but it doesn’t mean that it is wrong. I do recall that folks on this forum have reported that PS Audio has advised to specifically turn off AND unplug the PMG DAC in order to reset some streamer issues. Perhaps this gives you some other perspectives to think about.
