PMG Phono Question
Is the design the same as what we saw at AXPONA, Paul, in that there is no transimpedance input?
The PMG phono does have a transimpedance input in addition to the voltage inputs. If you have a low impedance moving coil cartridge the transimpedance stage sounds amazing
Hey, great! :smiley: Not sure how I missed that when I saw it in Chicago.
You speak of voltage inputs in the plural. Looking at the website picture of the back of the PMG Phono I indeed see both RCA and XLR voltage inputs. If I use the RCA input for my tonearm with a mono moving magnet cartridge, will I be forced to use the RCA transimpedance inputs for my tonearm with a stereo moving coil, or will the menu also allow me to use the XLR input for my moving coil? I ask because many moving coils have a high enough internal resistance that one might prefer not to use the transimpedance option. Another problem possibly forcing transimpedance is that most moving coil setups don’t have an XLR output.
Could be an excellent match for my Mutech Hayabusa, which currently favors a Sutherland Little Loco.
Mutech Hayabusa
I’d consider transimpedence as a special application for very low output/low impedance moving coil cartridges with a coil resistance of 6 ohms or less.
Yes that is exactly my concern, though your cutoff of 6 ohms is lower than other values I have seen (10, 15, as high as 20). If you are right I will not love the reproduction of my 12 ohm Audio-Technica ART9XA using the transimpedance option, so unless I toss that cartridge (and my Shelter models), I would need to use two voltage inputs to support both my MM and MC tonearms. Thus I asked if there is a menu option for two voltage inputs. But even if this option is on the menu (which I doubt), both my tonearms have RCA outputs and I would be loathe to use an RCA-to-XLR adapter for such a low voltage. My fear is that, by catering to the transimpedance option, the PMG Phono is likely for some users to be less flexible than the Stellar Phono. I do acknowledge the majority of users likely use only one cartridge/tonearm at a time.
Actually, IIRC Ron Sutherland had suggested a limit of 2 ohms for optimal performance with the LOCO series of phono preamps. The only way to tell is try them, not so easy these days.
Well a phono cart is balanced by its nature, and the RCA connector is a compromise. While I do use RCA in my system, changing the cable to XLR is a distinct possibility. Personally neither cartridge you mentioned AT or Shelter are good candidates for a transimpedance phono stage.
“My question is, since the PMG phono preamp uses transimpedance, will it work with Soundsmith’s low output cartridges.”
Yes. The transimpedance input on the PMG Signature Phono is optional. It also has a standard MC input with 470 Ω and 1k loading and up to 70 dB of gain, so Soundsmith low-output cartridges like the Zephyr MIMC Star, Paua MkII and Sussurro MkII should run fine on that input, just as yours does on the Stellar. I’m planning the same path with a Paua. Has anyone seen a review of the PMG Signature Phono yet?
Welcome!
It is not in production yet, so no reviews. Have to wait for 2027.
Soundsmith carts have internal resistances in the 10-11 Ohm range, making a transimpedance stage an iffy thing for them. Even if it does work, the current stage will likely not be operating in an ideal condition.
Agreed, the TZ input isn’t a good match for Soundsmith’s 10–11 Ω cartridges. My understanding is the PMG Signature Phono also has a standard MM/MC input with 470 Ω and 1k loading and up to 70 dB of gain, so a Soundsmith would run on that input instead of the TZ. Do you know of any reason that wouldn’t work well?
Should work fine. I run my Sussurro Gold on the MC input of my MoFi MasterPhono at 1KOhm and 60dB gain. I prefer to run my preamp volume higher and phono gain lower, if the configuration allows for it.
You’re right that a cartridge is balanced by nature and RCA is a compromise. Instead of changing the cable to XLR, has anyone tried a short adapter into a balanced XLR phono input, wired RCA center to pin 2, sleeve to pin 3, and pin 1 not connected, with the arm’s ground wire on the ground post? That keeps the signal balanced from cartridge to stage without rewiring the entire arm.
I know some will say an extra connection is the last thing a phono signal needs. But a good passive adapter is just one more solid contact, and in exchange the whole run becomes balanced into a differential input.
Curious whether anyone has tried it and heard a difference.
This weekend I came across a reference to the Musical Fidelity LX2-LPS phono preamp (now discontinued). It had an extra pair of RCA jacks labeled MM Load. It allowed changing the standard 47k load to something lower by plugging in RCA jacks with resistors wired across the pin and ground. This could be useful for certain Grado cartridges. It puts the resistors in parallel with the standard 47k load.
Seems like a nice feature for a high end phono preamp that wants to accomodate any cartridge. Especially if you could toggle it in and out of the circuit for listening comparisons.
The MoFi MasterPhono has that feature! :grin:
