Ps Audio DirectStream DAC input voltage
Hello!
I’m intended to buy used Ps Audio DirectStream DAC and have some concerns about input voltage.
This particular device is made for US market, the label says “100-120V”:
s-l1600
Will it properly work with 100V only input power?
Thanks!
First, obtain the serial number. If this DAC is still under warranty that is nice. I suggest that you call customer service at PS Audio for advice, especially if you intend to use it outside the USA. Also, PSA will be able to tell you its history. If you decide to buy it, they will register it over the phone for you.
You will find the PSA people very helpful.
Good Luck
Chas
