PS Audio NuWave Phono Stage
#1
I’ll start with my set up as it may help,
Clearaudio Performance,
Dynavector DV-20x2 cartridge
so I’m using the Hi Fi news test lp to set up my TT. On side A I get to the Bias setting test of track 8 and the Nu Wave starts clipping and speakers start to buzz. Adjusting my anti skate does nothing to rectify.
The cart is set to 1000ohms,2.5mV, and the arms arc is set and the VTF is set to 2.0g.
I can’t think for the life of me what I am doing wrong? any help would be greatly appreciated.
Kind Regards Gummo
#2
When I received my NPC, I set the dip switches and the input level according to my cartridge spec’s and it seemed to be fine, but before long I noticed a number of LPs sounded pretty bad and exhibited clipping during loud passages. I fiddled with the dip switches and the input level until I found a combination that sounded better. I’d suggest doing the same. Provided your tracking force is set at the Dynavector’s recommended spec and you’re not getting mistracking or sibilance, I’d leave that alone. The anti-skate setting is unlikely to impact the clipping.
Good luck.
-Pb
#3
So I changed the dip switch to 47k ohm and no change. I then changed to 100 ohm and that has removed the clipping sound but still left with the buzzing sound. My gain and VTF are set to the manufacturers specs, arc is set. So I’m unsure what it could be. It passes the first 2 bias tests on the test record buy not 3rd or 4th. Hmmmmm
Maybe it’s telling me my are and carts suspension isn’t really that good?
p.S. I appreciate your help with my matter.
Kind Regards
Gummo
#4
It sounds like something’s amiss with your cartridge. You might try reducing the gain to see if that has any effect, but I rather doubt it, since it looks like you might have a problem.
#5
Gummo,
You might try checking all of the leads to cartridge, making sure they’re firmly on the pins and not shorted somehow. Also check the connections on the phono cable to the junction box and the interconnects from the junction box (or however your TT is setup) to the NPC.
-Pb
#6
In realize that this is a sledgehammer approach, but does increasing tracking force change the result in any way?
J.P.
#7
Hi Gummo,
You have also I believe posted your concerns on the Stereo.net forum in Oz and some of your concerns have been answered there.
I commented that it might not be possible to get your arm/cart combo to track all the tests on the LP you are using (HiFi News Analogue Test LP). I checked the review (and also my copy) and thought it might assist to bring this to your attention again…UNDERLINING is by me. I hope this helps.
Review by TNT of this test record
This no ordinary record review. Here we are not concerned with music, but with a record specifically designed to help you set up your cartridge/arm so that when you do come to play music you will get the best out of them.
This is a fairly new recording (1996) made for Hi-Fi News in conjunction with Len Gregory - “The Cartridge Man” of modified AKG and Grado fame. It contains no music, just a series of squeaks and beeps and hums designed to confirm you as a real hi-fi addict…
I’ll go through the various tracks to show the scope of the disc:
First is a simple left/right channel test. A voice from one speaker, then the other. Blindingly simple and a sure test for when you’ve been fiddling and are not sure which side the first violins should come from. The voice itself is a good test of reproduction - we are all used to the human speaking voice so faults are easily spotted
Second - Phasing. Here a voice is recorded in and out of phase, allowing you to spot instantly if you’ve got speakers/cartridge or interconnect leads wrong. Takes seconds and saves minutes especially if you’ve been fiddling with the crossover and have a nagging doubt… (We’ve all done it…)
Next a -20dB Pink noise left and right to see if the tone of both channels is the same. It’s quite likely to be different if your room is asymmetrical like mine, but at least you can see the extent. The following two tracks do the same for left and right separately.
Now the most useful tracks of all…
The last four tracks on side one are 300 Hz tones played at +12, +14 +16 and +18 dB. These look horrendous with huge groove excursions. As the level increases your cartridge will mistrack, heard as a buzzing/crackling. The beauty of this test is that one channel will mistrack first. This is because the stylus will be pressed harder against one wall of the groove than the other, the one in less intimate contact will let go first.
By adjusting the anti-skate of the arm the stylus can be brought into equal contact with both sides of the groove. At this point the mistracking will disappear or be equal on both channels.
I’ve yet to find a cartridge that will track all the grooves perfectly so this simple test allows you to set the perfect anti-skate setting for your arm. It’ll show you how vague the normal method of setting the same anti-skate as downforce is :-)
It also allows you to fine-tune the downforce. One way of reducing mistracking is to increase downforce but this will only help up to a point and the downside is that the coils/magnets of the cartridge will be forced out of perfect alignment and so effect the performance.
The range of playing weights specified by a manufacturer are generally those where the innards are perfectly aligned, by using the test record you can judge when increasing the tracking force ceases to reduce mistracking. Inevitably this setting involves compromise but at least now you can make an informed choice.
A word of warning. These tones only test how well a cartridge tracks a 300 Hz test tone - not music! As a measure of relative tracking ability of various cartridges they are a guide only and the tracks on Killer records are a better bet…
Side two begins with another 300 Hz test tone and this is repeated in the middle and end of side two to check consistency of tracking. The result is that minor changes in cartridge alignment will make all three playable with equal fidelity.
Track two and three are sweeps from 25-5 Hz along with a 1 kHz tone. Track two is in phase so gives a horizontal movemant at the stylus, track three is out of phase so the movement is vertical. It sounds complicated but what happens is this… You’ll hear a tone and a voice counting down the frequency. At some point the tone will “warble” and the cartridge wobble visibly. This is the resonance frequency of the arm/cartridge.
If the resonance is too low - say 6 Hz as with a very compliant cartridge and a high mass arm the result is a cartridge very sensitive to footfalls and a sod to cue. On the other hand if the resonance is to high - say 20 Hz as with a low compliance MC cartridge and an ultra low mass arm the resonance will be audible and will colour the sound. Though this test does tend to spot when you’ve bought the wrong equipment it can also show the effects of changes in damping.
Last but one is a cartridge azimuth test. Here a 300 Hz tone is played out of phase. If the Azimuth is correct the sound level will be the same from both speakers but they should cancel if the amp is switched to Mono.
Last is an unmodulated groove i.e. silent. This is a cracker for seeing the effects of different plinths on rumble, supports on feedback etc.
So nothing very interesting to listen to, but an essential part of any record collection. I’d go as far as to say that this disc is as useful as an alignment gauge or a stylus pressure gauge and we know that no vinyl nut would be without either of those. For the cost of a full price CD it would be foolish to let the sound of your expensive turntable be well below par…
