PS AUDIO p10 Shor Circuit message
#1
Hello
from a couple of months i get this message when i power on the PS10 “short circuit” and i cannot do anything else that unplug the power cable and retry, somtimes re-start immediatly and sometimes i have to re-try different times.
What the Hell??
Thank you.
#2
What is it you have plugged into the P10? It will give you this message when it thinks there is exactly that on its output. This can be from a shorted power cable - and sometimes they are intermittent - or an amplifier that’s not on the HC outlets.
#3
Dear Paul
thank you i will check and revert back.
#4
Thanks. It’s telling you it’s unhappy with something on the output of the P10.
