PS Audio Statement SC cable fail
This is a first for me.
I use a Statement SC power cable and changed the piece of gear that I use the cable with.
Now in the new gear, the power cable isn’t working correct. WHen I put it in and hold it tight in the amp, it works. When I let go, the amp turns off.
I then tried it in a phono pre and a DAC, same issue.
Something inside the IEC connector must have failed somehow.
How long is the warranty on power cables?
Thanks,
Raymond
Our products are warrantied for three years. Contact us when you can for help. There is no way to repair the cable, we would have to replace it.
