Purchase from factory direct
I will be going to see family in Denver next week. Can I purchase and pick up from the factory direct?
Thanks,
Marcus.
Welcome!
I bet they will work something out with you. I suggest giving them a call: 720.406.8946.
Thanks, Elk! You bet. As long as we have it in stock, and we do for most products, you walk in the front door, get a tour of the facility and maybe a listen, and walk out with your new kit.
Thanks very much for the quick responses. May I just check if you are open on the weekend?
Nop.e We have a pretty strict rule about weekends. Spend time with your family. Doors are closed at 5PM Friday and open again early Monday morning.
Good for you. I will work around that. Thanks for the responses.
