PW DAC not functioning after upgrading firmware
#1
I upgraded the firmware for my DAC and it appeared to succeed. I powered down to adjust my components and when I turned the unit back on the display was divided in half - right side bright, left side dark - and the unit was completely unresponsive. Is there anything I can do to fix this problem? Thank you.
#2
You may have a corrupt file somewhere. You might try installing a previous firmware version and then go back to the current one (with a fresh download).
#3
Thank you. I tried what you suggested and after downloading an earlier version of the firmware it still has the same problem. It seems like it may be a hardware not a software problem.
#4
It is probably not a hardware issue.
Give the denizens of PS Audio a call. I bet they can solve it.
In the meantime, I am sorry you are having a problem. Very frustrating.
