I just removed the Bridge and am thinking of getting a PWT.
Do I need to keep the SD Card installed if I don’t have the Bridge?
Hi,
Why remove your Bridge? We are testing the Wavestream software now which sounds great and promises to solve all the Bridge concerns. I sold my PWT because it was unused with the Bridge.
The SD card could be removed if you want but I’d leave it in so it can be used to display your album art.
Steven
album art is displayed only for bridge input, so you can safely remove the SD card.
You will need (temporary) one when upgrading PWD firmware in future though
I would leave it in until you need the card for a firmware upgrade. The PWD provides a good SD card storage slot.
