router is in the same room. i’m trying to keep my system very simple so i’m using the PWD as my preamp. i guess that could open up a whole new discussion. MinimServer it is!!! It will take a few days but will report back with my findings. is this the right download for the 213J…Synology ARM: MinimServer-0.8.1a-arm.spk??? thanks for all the suggestions
don dac said: is this the right download for the 213J....Synology ARM: MinimServer-0.8.1a-arm.spk???
I do not know what CPU is used in your NAS. You can try it anyway, if the architecture is wrong, the package will be refussed ;)
don dac said: i guess that could open up a whole new discussion.
We already had many ;) The question is still open.
don dac said: MinimServer it is!!! It will take a few days but will report back with my findings. is this the right download for the 213J....Synology ARM: MinimServer-0.8.1a-arm.spk???
You can check what processor your Synology uses at Synology's website.
You must also install Java on your NAS before installing MinimServer, and this can be the harder of the two things. The MinimServer website contains the necessary info.
