PWD MK-II Will not power up
#1
Hello
Yesterday (sunday evening) I powered up my system and everything went up accept my PWD MK-II. Checked all the connections to the P5 (which works). Plugged the unit into the wall socket and still no power. Any thoughts on this? Where can I go from here?
Worried in Boston – Jim
#2
Unplug the PWD and let it sit for an hour. Plug in and try to power up again. If this does not work then there is a fair chance that a fuse is blown. The fuses are 20x5mm 1A slow blow. If you need help removing the top cover to replace the fuses, just ask. There may be instructions in the Knowledge Base, it has been a while since I have looked.
J.P.
