Need instructions (for a friend) how to identify if PWD has a MK II upgrade board on it.
I cannot see it on the starting screen when the PWD boots.
Thanks
Off hand, it is a MKII if the following questions are "Yes."
Does it have a rear panel sticker indicating MKII?
Does it have a balance control?
Does it have a remote with a balance control?
The PWD was a MK I and the question is if it was upgraded with the “Upgrade Kit” to MK II ?
Thanks.
And I answered precisely that question.
1) The upgrade kit came with a sticker.
2) The upgrade kit adds a balance control for which it is easy to check.
Otherwise, open the critter up and examine its innards.
We’ll check. Thanks.
Also, Mk II has a “Native X” mode, the original did not. (Balance control will be on the remote as well as noted above, and I think that Power Plant controls are added, not sure if they were on the original remote).
lonson said: I think that Power Plant controls are added
Yes, indeedy. The old remote has controls for the "Lens."
amiglic said: We'll check. Thanks.
Feel better now? :)
