PWT bootstrap loop
Hi all,
after some years of happy listening i’m not able to play CD’s anymore with PWT.
Few days ago, all of a sudden whenever the PWT is switched on from the back AC button, the bootstrap sequence enters a never-ending loop.
Half second after the opening screen has appeared (“insert disc”), the display gets black two seconds long and the whole starting sequence begins once again with the initializing screen (“initializing”), and this loop repeats endless until I switch the PWT off with the AC button.
I have already tried to disconnect the power cable from the socket wall and reconnect it the day after, but nothing has changed. PWT firmware version 1.24.
Any suggestion is welcome.
Thanks, Ric
Download another firmware to the SD card. Insert it into the PWT with the power off. power up the PWT and see what happens. If this breaks the cycle than download the most recent firmware to the SD card and reinstall it. This may or may not help!n I would would give it a try though.
At last I’ve been able to solve the trouble, so I would like to share the solution in case anyone should have the same issue.
Downgrading/upgrading the firmware version did not help at all.
Nevertheless, the PWT has always been being connected to the local network and, from a certain moment on, something got wrong with the “handshake” between the network router and the PWT during the bootstrap process (the PWT DHCP mode is “on” by default, so the router tries to assign a “free” IP address to the PWT when it “asks” to join the network).
First of all, I discovered the bootstrap process went fine whenever the ethernet cable was disconnected from the rear panel socket. Reconnecting the ethernet cable once the starting sequence has ended, the PWT gets the IP address and everything runs ok.
I’m assuming the defect is on the PWT side and not the router/local network side because many other devices are connected with DHCP mode and they have no issues when restarting. Among others, I checked of course the PWT gets an IP address not conflicting with IP addresses of any other network device.
The solution I found was to change the PWT default network configuration disabling the DHCP mode and assigning the PWT a “manual” IP address (this can be done via browser writing the PWT IP number in the top address bar). On router/network side the PWT “manually assigned” IP address has to be marked as reserved, so no other devices with DHCP mode can get the same IP number.
Doing so, the PWT bootstrap process runs smoothly without the need of disconnect/reconnect the ethernet cable.
This is the picture of the PWT network configuration page :
This is good to share as someone else may come across the same issue. I used a PWT for 6 years connected to a router and never had this issue so the fault you describe may be more related to your particular router than the PWT itself. Thanks for the info though.
I now use a DMP and that is an animal with all it’s own quirks!
