PWT display and power button brightness level
The power button and display on my PWT seem to be very dim in comparison to my DS DAC. The brightness of the PWT is comparible to the lowest setting of display brightness on the DS. Is this normal or indicative of a pending problem?
Doubtful. I have never seen display grow dim with time. More than likely they’re from two very different batches of production.
Did you check the dimmer display set up menu in the PWT? It can be made to display in fixed or auto dim mode.
mark-d said Did you check the dimmer display set up menu in the PWT? It can be made to display in fixed or auto dim mode.
Agree with this - the default is "auto dim" which changesw the brightness according to ambient lighting level - I changed it in set-up and haven't had an issue since.
Where is the “dimmer display set up menu” ?
You can access the setup by “touching” the PS Audio logo on the screen during initial power up (turn the power switch from off to on at the rear of the unit)and then change the display/dim setting to your preference…
Thanks very much for the help. Found it.
Cool… Was that the problem then?
