PWT Help Needed
I have PWT Serial Number PWT-B1-9G003144 running firmware Version 1.22. I also have a PWD II Serial Number PWD-B1-9F001727 running firmware Version 2.4.6. The PWT is connected to the PWD via I2S. Today I tried to play a CD and got no sound. The PWD display showed the disc was playing but no sound. I tried a DVD+R disc with 96/24 files on it and got the same result; the display showed that the disc was playing but no sound.
I have a Wadia i170 iPod Dock connected to the PWD via a coax cable. That played correctly.
I switched the PWT from I2S input number one to I2S number two and got no sound.
I connected the PWT to the PWD with the same coax cable that the i170 iPod dock was using and still no sound. I connected the coax from the PWT to my HHB CDR-800 CD Recorder and tried to make a digital copy and got nothing.
In summation, the PWD works with its Coax input from the iPod Dock but not from the PWT. The PWD does not work with either I2S input from the PWT.
Any help would be greatly appreciated.
David Schwartz
pmc7027@comcast.net
