Radio Transmission Noise through Phono Preamp
Have you tried different phono cables? I wonder if you need cables with a bit more shielding.
Unfortunately my phono cable was built directly into the arm by Acoustical Systems so I can change the tonearm cable. I will try some of the ferrite clamps. Note that I also had a similar problem with my Rega RB Arm on my Rega Planar 8. So I am having the same phenomena with different turntables, different cartridges, and different phono preamps. I might just be cursed with living in a high radio transmission area. Will report to you guys once I get back to listening. I have been busy moving my mother yet again into a different long term care situation. Life’s journey continues.
My heart goes out to you. We just did the same with my Wife’s mother. It’s necessary, but heart wrenching. I hate being mortal.
I wonder if one of the purpose built grounding blocks might work. I seem to remember a thread here on the forum where there was a discussion about one particular product.
Here it is:
Actually going to get a grounding device in the future. Leading contenders are CAD and Synergistics fancy contraption.
What’s this CAD?
I’m planning to drive another ground rod into my yard soon, just to see.
This is the CAD grounding device,
and this is Synergistic’s priciest option. They have lower priced versions.
Not sure if they will solve my current problem but I know that the CAD device knocks down a systems noise floor. I heard it and I want something like it.
I live in a condo complex. If I was in a house I would also be driving rods into the ground. :slight_smile:
You mean all of your neighbors below won’t appreciate a shiny copper rod going through their living rooms? What has the world come to?
Yikes! Is the voice telling you to do anything bad?
Why do the voices never suggest something pleasant, such as “Take everyone on a picnic!”
Mine do all the time. They’re just not talked about; completely useless as click bait.
I just need my voice(s) to whisper: “Vince the Powerball winning numbers are going to be…”
Then I’ll need another voice to remind me several times to go buy a ticket. And another to tell me where to buy them. I think the corner pub might.
Alright. Have to go back to basics. The tonearm cable grounding cable was attached to a grounding post on the phono preamp. Moved that tonearm grounding cable to a couple of different grounds and got rid of radio station but still have some humming. Better but still room for improvement. Lesson learned…goof of and experiment with grounds. More goofing off to be done.
It’s a process, takes time, but you will get there at so e point. Thank you for sharing your experience on this matter.
Also check for light dimmer settings that may increase/decrease your hum. That drove me crazy for a while.
And see if your phono pre is plugged in to the same branch circuit as your preamp, amp, etc. If you have ground loops from the mains feed that can cause hum as well. Next step, run your phono pre from an isolated UPS! (just kidding, sort of).
I wish I saw this thread sooner. I have had this same issue, for years. My audiophile friends found great joy in teasing me about it. One of my reasons for getting a Power Plant, was in the hope that it would solve the issue, but it didn’t.
I would pick up different radio stations, at different volume levels, intermittently, always while listening to my turntable.
The radio interference would appear with different phono stages, and (generally) disappear when I unplugged the turntable. I have a ground lift option on my phono stage (Valve Audio Whisper). I don’t actually know which switch setting is “lifted” and which not - but on one setting I would hear radio, on another I would hear hum. The radio signals were less irritating.
Only recently I discovered that, if I place my hand on the power supply side of the phono stage, the signals would be greatly amplified. Clearly I could become an antenna if my day job doesn’t work out.
But then I found something interesting - the power cable plugged into the phono stage (a Supra cable), didn’t fit tightly. When I lifted it, so it fitted exactly into the power input, the RF would disappear.
I was planning to switch the cable for a set of Shunyata Venom NR-V12. Since I’ve done that, I have not heard any radio noise, or if it’s there, the volume is extremely low.
The moral of the story for me, is not to jump to any quick conclusions. Even if the signals might come from the turntable, getting rid of them may not require changes to that side. Best thing is to take your time and test and observe different things - especially before you spend big money on something that may not work.
