Rapid tick in BHK Signature Preamplifier
Any suggestions on what the problem might be or how to fix ? I have not tried changing the tube . Any suggested recommendations for tube replacement ? This pre is with a complete PS Blue wave system , transport ,DAC, pre, amp and the 250 watt BHK amp. System is about 7 years old .
I remember that happening to me after a power outage - the BHK ticked rapidly (not form the speakers, from the unit). I turned everything off, unplugged it, and left it for a while. It hasn’t returned.
If the ticking is coming from the speakers vs the unit then it’s something different. Hope you get it worked out.
Thanks Tom, in the past hour I replaced the 12au7 with new Psvane tubes . Same noise perhaps slightly louder about 20 or 30 db with meter right at the driver mouth
with a slight flutter to the TICK sound . I have very sensitive Oris horn speakers about 102 sensitivity .
Interestingly my noise started after unplugging all units for a thunderstorm . When i powered system up couple days latter is when sound appeared. Months later I took trip in my camper for couple weeks so unplugged system, on return and powering up noise was gone , but then returned again after repeating this power down and up theme. I have repeated this process several times to no improvement .
Seems similar to what I experienced. Actually, now that I think about it I have had this phenomena a couple times. Mine resolved after power down, rest, and up. Sounds like that is not working for you. Time to ask PS Audio Service department for a consult.
Welcome!
My BHK Pre has had a fast paced tick while in standby since the day it arrived from PS Audio. Doesn’t usually come through the speakers though. But if I’m standing close to the Pre while it’s in standby, I can hear it ticking away. Wonder if you’re experiencing the same thing.
