ROON to Bridge II playing as Wav
Hi there,
When I am playing tidal from within Roon I am outputting to Bridge II. The format showing on my DS is Wav. When I play the exact same song from mconnect to the bridge II it shows the correct format as Flac or Wav.
Is this correct behavior or should Roon be passing the exact format to the bridge II?
Cheers
Andrew
wallyhk said
Hi there,
Cheers
Andrew
This is correct. Currently Roon does all of the decoding and sends wav streams to the bridge.
Dennis
Thanks for clarifying
Regards
Andrew
