Roon w/ Nucleus+ DSP Engine Sample Rate Conversion
I just set up a Roon Nucleus+ driving a PSA DS DAC. Thoughts on the Sample Rate Conversion settings in the DSP engine. Has anyone established “best” settings or investigated changing settings. The only change I made was to enable the use of multiple cores. I will be implementing convolution filtering in the next month or two and figured this would help processing the filter.
I eventually turned off the DSP and let the PSA DAC do all the magic. Did you ever get an answer back from anyone on the preferred Roon DSP settings?
@rnktay1994 - no, never got an answer on this thread; however, I turned the DSP OFF as you noted and it worked fine.
