I’m considering upgrading my PS Audio stack and am looking at moving from the M1200s to the S400 to drive my FR 10s. If anyone here has insight as to how much additi9nal heat the S400 puts out, that would be appreciated. It will be in an open rack with at least 4 inches open on every side.
My major concern is that the room my gear is in gets warm —not enough to damage equipment but enough to raise the temp to mid-80s, becoming uncomfortable to listen. Lowering a/c temp not really an option for this room.
Thanks guys. Based on your comments and digging deeper to covert power output to added degrees F in my room, it looks like I could see something between 2-5F after a few hours with door closed and 1-2F with the air moving.
The purest in me wants the Class A of the S400 to match with a PMG Signature pre and the 512 DAC. The good thing is the trial period will let me see the real world impact, particularly as I burn-in the S400.
I use the S400 for the bass unit of FR30s and M800s on the upper unit. In the warmer months I keep the room at 75 but for critical listening turn off the AC. After 2 to 3 hours the temp reaches 77 to 80 depending on outside temp. My room (not attached to the house) is very well insulated and holds the internal temp well. The 400 runs hotter than one 800 but cooler than two 800s.
