Small Signal Tubes Part 3
Items as described and shipping is extra. The Tung-Sol tubes are original production and not New Sensor Russian reissues except where noted.
12AT7
GE JG 12AT7WA: 1 tube, July, 1955, used about 30 hours, $35.
Philips ECG JAN 12A7WC: 1 tube, October, 1987, NOS, $15.
Raytheon 12AT7WA: 1 date matched (October, 1964) pair, 1 NOS and 1 used 20 hours, $60/pair.
12AU7/ECC82/CV4003/6189
Brimar CV4003: 1 tube, NOS, $60.
Electro-Harmonix 12AU7: 2 tubes, NOS (2001), $20/pair. Philips JAN 6189W: 1 pair, October, 1987, used 40 hours, $40/pair.
5687/7044/7119/E182CC
GE JG5687WA: 1 matched pair, black plate, 1961, used about 30 hours, $70/pair.
GE JG5687WA: 1 matched pair, black plate, 1961 and 1963, used, $50/pair.
Raytheon 5687: 1 tube, black plate, used, $20.
Raytheon 5687: 1 matched pair, September, 1964, used about 40 hours, $45.
Raytheon CK5687: 2 tubes, used, $20/each.
Tung-Sol 5687: 1 tube, D-getter, black plate, 1955, used about 30 hours, $35.
Tung-Sol 5687: 1 matched pair, bronze plate, used about 25 hours, $60/pair.
Tung-Sol 5687: 1 matched pair, bronze plate, NOS, $100/pair.
Tung-Sol JTL 5687: 2 tubes, D-getter, black plate, Nov. 1951 ad Nov. 1955, used about 30 hours, $35/each.
Tung-Sol JTL 5687: 1 matched pair, D-getter, black plate, used about 20 hours, $80/pair.
GE 7044: 4 tubes, used, $20/each.
Sylvania 7044: 4 tubes, used, $20/each.
Amperex 7119PQ: 1 date matched pair, plus single white label, Holland, NOS, 1962, $125/pair, $60/single.
Amperex 7119PQ: 1 date matched pair plus single tube, white label, Holland, NOS, 1963, $125/pair, $60/single.
Amperex 7119PQ: 1 matched pair, white label, Holland, NOS, 1965, $125/pair.
Amperex 7119PQ: 4 tubes, white label, Holland, used, $20/each.
Amperex 7119PQ: 3 tubes, orange label, Holland, NOS, 2 are 1973, $50/each.
Amperex 7119PQ: 1 matched pair, orange label, Holland, sources from Upscale Audio, $100/pair.
5751
GE 5751: 2 tubes, used, $25/each.
GE JG5751: 1 date matched pair, triple mica black plate, Jan. 1957, 50 hours use, $100/pair.
GE JG5751: 1 matched pair, triple mica black plate, 50 hours use, $100/pair.
RCA 5751: 1 date matched pair, black plate, 50 hours use, $100/pair.
RCA 5751: 1 matched pair, black plate, sourced from Andy at Vintage Tube Services, 50 hours use, $100/pair.
RCA 5751: 2 tubes, black plate, NOS, $75/each.
Sovtek 5751: 1 pair, used, $20/pair
Tung-Sol 5751: 2 date matched pairs (1960), used, $50/pair.
6CG7/6FQ7
Electro-Harmonix 6CG7EH: 1 pair, used, $20/pair
GE 6CG7: 1 matched pair, gray plate, NOS, $100/pair.
RCA 6CG7: 1 Cleartop, used, $25.
RCA 6CG7: 2, used, $20/each.
RCA 6CG7: 2 tubes, black plate, NOS, $50/each.
RCA 6FQ7: 1 Cleartop, used, $25.
RCA 6FQ7: 1 matched pair, Cleartop, sourced from Andy at Vintage Tube Services, $50/pair.
RCA 6FQ7: 4 tubes, used, $20/each.
Sylvania 6CG7: 4 tubes, used, $25/each.
Sylvania 6CG7: 2 tubes, D-getter triple mica, used, $25/each.
Sylyania 6CG7: 1 matched pair, black plate, April 1958, sourced from Jim McShane, used, $75/pair.
Sylvania 6CG7: 3 matched pairs, D-getter tripe mica, gray plate, used, $50/pair.
Tung-Sol 6CG7: matched pair, NOS, $100/pair.
Tung-Sol 6CG7: 1 tube, NOS, $50.
Tung-Sol 6CG7: 1 tube, 1965 production, used about 20 hours, $25.
Tung-Sol 6CG7: 1 tube, black plate, used, $20.
Tung-Sol 6CG7: matched pair, 1958 production, used, $50/pair.
6DJ8/ECC88
Amperex Bugle Boy 6DJ8: 1 tube, Holland, 1965, used about 50 hours, $20.
GE 6DJ8: 1 pair of gray glass, used, $35.
GE 6DJ8: 1 tube, used, $20.
RCA 6DJ8: 1 tube, Holland, A-frame getter, used, $20.
RCA 6DJ8: 1 tube, Siemens made, 1977, sourced from Brent Jessee, 20 hours use, $30.
Telefunken 6DJ8: 1 tube, NOS, $100.
6922/E88CC
Amperex 6922PQ: 1 tube, white label, Holland, 1963, NOS, $150.
Amperex JAN 6922: 1 tube, 1971, NOS, $50.
Amperex JAN 6922: 1 tube, 1977, NOS, $50.
Chinese 6N11: 5 tubes, NOS, $15/each.
GE 6922: 1 tube, Great Britain, seamed top, dimple disk getter, used, $20.
GE 6922: 1 tube, Great Britain, seamed top, A-frame getter, used, $20.
6H23π-EB/6922
6H23π-EB Type 3: 3 matched pairs, sourced from Upscale Audio, used less than 100 hours, $50/pair.
6H23π-EB Type 3: 3 matched pairs (Voshkod plant) and single tube (Saratov plant) 1979-82 production, less than 75 hours use, $50/pair, $25/single.
6H23π-EB Type 2: 4 matched pairs 1980 production, sourced from BOI Audio Works, used less than 50 hours, $40/pair,
6H30π-EB/DR
Sovtek 6H30π-EB: 5 single tubes, 40 hours use, $20/each.
Sovtek 6H30π-DR: 2 single tubes, military grade, used, $50/each,
5691/6188/6SL7WGT
JAN Philips ECG 6188: single tube, 12/85, 50 hours use, $35.
JAN Philips ECG 6SLWGT: single tube, 9/85, 50 hours use, $35.
JAN Philips ECG 6SLWGT: single tube, 9/85, NOS, $50.
RCA Red Base 5691: single tube, sourced from Upscale Audio, less than 100 hours use, $75.
RCA 6SL7GT: 2 tubes, NOS, $75/each.
Joe,
I may be interested in some of the 6DJ8/7308/6922 tubes, but I may have to wait as I just purchased a couple of pairs recently and haven’t had enough time to roll them all through my ARC LS7 pre-amp. For now, it seems my best tubes are 6DJ8 A-frames with dimpled disk getters; one pair (actually 3 tubes) orange-world label Amperex/Holland and one pair red label Mullard/Great Britain pairs. All 5 tubes look the same, other than the labels. Also a pair of 6DJ8 West German Telefunkens. 6 of 7 of these tubes came from Brent, one of these tubes is from TC Tubes.
I recently/briefly had a pair of Philips JAN 6922 that rang so badly I couldn’t use them.
Brent Jessee was always a reliable vendor in my experience and had a good selection. TC Tubes was another I used in the past.
I try to keep my listings up to date so if something catches your eye when you’re ready then let me know.
Regards,
Joe
