Sprout100 connection to Android tablet?
Hello. Was wondering whether is possible to connect an Android tablet to the Sprout100 via the USB/Toslink input. If so, what type of cable should I get? Thank you.
Yes, It’s doable. I connected my samsung tablet to my Sprout 100. I used a special USB cable that went from my tablet to the Sprout 100. I would look online for the specific cable you would need to connect your tablet to the Sprout. Hope this helps…
Kindest Regards,
Thank you. I believe this would be the right sort of cable.
That looks like it would work.
Kindest Regards,
