I have something like 7 sets of EQs in place. I noticed the most impact under digital components, mainly streamer & dac
I got CSA1s for my Bhk pre and Mk1 dsd dac. I’m very happy with them, I heard a difference instantly. I think there’s a bigger improvement from using them on my Bhk pre because of the tubes vs the mk1 dac.
I have 15 sets of AUVA’s under all manner of audio gear…anything that passes audio and has a flat bottom. Various degrees of improvement noted. Frankly, at this point, I remove the factory feet as a matter of course with everything and replace them with Stack’s stuff. At a fraction of the component’s cost, I feel the unit “incomplete” without the ancillary upgrade. Same with exceptional fuses.
I received six AUVA 100s today for use under the spikes of my Vandersteen 5A Carbons. It was a little tricky getting the spiked AUVAs level through my carpet and padding into the flooring beneath. If the weight of the speaker spikes wasn’t exactly centered, the AUVAs tilted as their spikes snapped through the carpet. My lovely, helpful, and game wife persevered with me (“Okay, tilt the speaker toward you again—now lower it”) through several iterations until everything seemed good.
My floor is carpeted plywood suspended on joists above the basement. Unlike those whose speakers rest on a concrete slab, I felt without actually knowing that my floor probably mucked with the sound my speakers’ powered subwoofers transmitted via their spikes into the plywood.
Anyway, I’ve found that the most obvious and notable change with the AUVAs in play is just how disentangled the low bass is now. I hadn’t realized it needed cleaned up, but wow, I do now. Bass notes “next to” each other are now easily resolvable and separate; in many cases I hadn’t realized there was so much going on down there. Bass transients always punched hard, but now they skewer. Sustained subterranean bass is way more palpable. Mid-bass also sounds as though it’s playing against a darker, cleaner background.
I can’t easily compare with the AUVAs versus without, given the effort required in my case to move between the two, so I can’t comment on other differences I might hear, if any. The bass improvement, however, was simply obvious.
Thanks for your suggestion about how one might use AUVAs despite needing speaker tilt.
— Chris
Your installation was waaaaay trickier than mine - but sounds like it was well worth it. Nice!
My AUVA 100s were installed to the base for my speakers, then the speakers added to the base. I didn’t use the spikes. I have zero idea how they “sound”. I never heard the speakers without them. Probably a good thing.
You probably need a set for the vivids once they go back in service.
Each Vivid has six feet. Yikes!
Can I attach them to my shoes? I have only 2 feet
If you do, you can likely start a second career as a celebrated singer.
— Chris
I think they will reduce the vibration on your feet so you should try them when you go hiking next time. ![]()
Stack 100´s replaced the already great 50´s under my GoldenEar Tritons. Wow what a blast, low level details, and just more musical enjoyment! Before that I had Gaia III, they were ok, but sold immediately when I heard the Stacks.
I also have the AUVA EQ`s under my amp, and thats also was a great investment towards HiFi heaven.
I believe we can add a new rule to our list of absolute truths.
- Add a Matrix V2/V3 or a similar device between your source and your PS Audio DSD MK1 DAC using a really expensive USB and HDMI cables between them. Bonus for spending a fortune on an external power supply, fuse and cables. Do this always.
- If you have speakers, put AUVA footers under them. The 100s seem nice. Do this always.
- And….
At first I had IsoAcoustics GAIA III under my GoldenEar Triton Three+, and that was a good step up on SQ compared to spikes. I than tried Stack 50´s, WOW what a change. More air, more bass, tighter bass too. Just a revelation. Sold the GAIA´s and was very happy. But what if… Got the Stack 100 and even more WOW! It’s Just love them
Its a keeper!
