Hi,
Two questions. First, does Stellar Gain Cell DAC USB work with Linux, namely Raspberry Pi variation? In Manual you do not mention Linux: “USB requires a driver to operate properly. Mac computers running OSX have the driver built in. Windows based computers require the PS Audio driver to be installed.” Elsewhere on your web site it is noted that Linux drivers are included in the Linux distributions.
If Stellar Gain Cell DAC is supported in Linux than I would need help getting it to work.
I tried my PS Audio USB DAC with moOde 5.4, 6.0, 6.1 on RPI2 and RPI4 and no luck.
I can choose and save USB audio device from Settings > Audio > MPDconfig but when I play music I get following error:
MPD error
Failed to open “ALSA default” [alsa]; Error opening ALSA device “hw:1,0”; snd_pcm_hw_params() failed: Input/output error
On moOde 6.0 I updated to ALSA 1.19 and that did not work either.
4 other USB DAC’s that I have work perfectly.
Ropiiee, Volumio, and piCorePlayer did not work either with the PS Audio USB DAC. 2 different Windows machines did work with the PS Audio USB DAC even before I installed drivers.
I see that DAC reports as Sprout100:
pi@moode:~ $ cat /proc/asound/card1/stream0
PS Audio Sprout100 PS Audio USB Audio 2.0 at usb-0000:01:00.0-1.4, high speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S32_LE
Channels: 2
Endpoint: 1 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000
Data packet interval: 125 us
Interface 1
Altset 2
Format: S16_LE
Channels: 2
Rates:
Interface 1
Altset 3
Format: SPECIAL
Channels: 2
Rates:
pi@moode:~ $
Do you have any idea how to make this work?
Regards
Vucko Zagi
