Stellar Gold DAC. I2S pinpoint
Hello - I have a Stellar Gold DAC and need to know if the I2S is compatible with the Shanling CT90 CD transport. The transport offers 10 pinpoint modes. I’m just not sure if it will match up with the Stellar Gold DAC. Thanks
According to Shanling they are compatible:
The CT90’s solution: an on-board FPGA that electronically remaps the I²S pinout to ten different standards. Cycle through modes from the front panel until the DAC locks on a clean signal. The supported modes, based on typical ten-mode implementations in this market segment, cover PS Audio, Denafrips, Holo Audio, Gustard, Rockna, Matrix, Musician, MHDT, Pro-Ject, and a generic/custom mode. Shanling publishes the complete 19-pin definitions for all ten modes in the manual’s IIS-LVDS output interface section, so you can match your DAC’s documented pinout on paper before you even start cycling.
Thanks Joe! It’s a big help.
