StellarGold Preamp 12V Trigger
I’m curious if anyone here has experience with this preamp and its 12V trigger out. I recently inserted this in between a streamer (Wiim Ultra) and amp (Buckeye Amps Purifi 2-ch). Previously the trigger from the Wiim to Amp worked fine. I swapped the trigger cable input from Wiim to SGP and no joy; even tried both the upper and lower jacks. Swap the input back to Wiim and all’s well. I’ll probably try to throw my multi-tester on at some point for an A/B test of the two device’s trigger output but was hoping somebody has been here before.
TIA
Welcome to the forum. I have not experienced this issue, but it has me wondering just in case you haven’t looked already, have you checked the trigger timeout setting? Per the manual:
"The Trigger Timeout sub-menu setting permits adding a delay to the trigger output signal to adjust the time between placing the StellarGold Preamplifier in Operational mode and when a power amplifier connected to the trigger output is signaled to power up. The delay can be set to one of “Off”, “0s”, “5s”, “10s”, “20s”, “30s”, “45s” or “1m”.
Check to see if the trigger cable is mono (TS) or stereo (TRS). I think Wiim streamers will accept either. For the SGP it must be a 2-conductor mono TS cable.
Aha! Thank you, that was it. I didn’t know there was a manual but after your post I went and downloaded it (I feel better now, I’m the guy that reads manuals cover to cover before plugging in!). I navigated to that trigger settings menu and sure enough it was set to Off. Changed it to 0s and works a charm, just like before.
Thank you so much!
Glad you found a solution! Yay!
