This topic is ment to see how users rate their streamer or source equipment in comparison with the best result they had with PS Audio Bridge1
The ratings scale is from 0 to 100 lets set the reference Bridge1 using Nass (Qnap T212) and cat6 cabling (Rated on 40).
The tests I did were with several ethernet cables Cat5,Cat6, Audioquest carbon Cat7
USB several brandless and AudioQuest Coffee
The I2S cables I tested several brandless, Monster, Kimber, Pink Faun, PS audio
The software that is used Elyric Manager, Amara, Jriver and a few others
Here’s how I would rate the sources I have tested. Some are how I have them in mind, because not everything is tested at the same time.
HP Mini laptop with Intel celeron processor 4GB Ram (bridge1 short cabling (rated at 45))
Sony 18,4Inch laptop Intel T8400 dual core processor 4 GB Ram used with bridge (bridge1 short cabling (rated at 50))
HP laptop 15,6Inch AMD forgot the specifications used with bridge (bridge1 short cabling (rated at 45))
Asus N53SV i7 2630QM Processor 16GB SDram used with bridge (bridge1 short cabling (rated at 55))
Mac mini Server 2012 I7 processor used with bridge (bridge1 short cabling (rated at 58))
HP Probook 6570B I5 processor used with bridge (bridge1 short cabling (rated at 50))
Desktop PC Asus Z87 deluxe fanless powersupply seasonic (intel core i7-4770 3.4Ghz, 8MB S1150) silent fan and 16GB DDR3. Used with Pink Faun I2S bridge (I2S Pink Faun cabling (rated at 76))
NAD M50 streamer used with Toslink (Toslink (Rated at 75))
Pink Faun audio streamer intel Atom processor linear powersupply and passive cooler used with Pink Faun I2S bridge (I2S Pink Faun (Rated at 78))
Pink Faun AV-streamer AMD processor 3,7 Ghz linear powersupply and passive cooler used with Pink Faun I2S bridge (I2S Pink Faun (Rated at 90)) Normal Settings for voltage and processor speed
Pink Faun AV-streamer AMD processor 3,7 Ghz linear powersupply and passive cooler used with Pink Faun I2S bridge (I2S Pink Faun (Rated at 96)) Custom Settings for voltage and processor speed
Equipment not heard in my own system, but compared with a few of my sources
PS Audio PWT (I2S Pink Faun (Rated at 76))
PS Audio Beta bridgeII (Ethernet (Rated at 85))
Hope to see your ratings!!!
