The occasional SACD layer question
PST to stock DSD MK2:
Occasionally does not recognize or indicate that it’s playing the SACD layer. When this happens it plays, sounds fine and indicates CD, 44.1. Removing the disk and trying a few times “fixes” it.
Does this happen to others? Any explanations?
Never happened to me with PST/MK2 in the past, and never happened with my PMGs now either.
you might check and see if the default layer is SACD, i think that’s suggested in the manual.
Thanks. SACD is the default.
It’s been mentioned here several times that restarting the PST regularly, say once a week, helps with the occasional odd behavior. I had the PST/Mk2 and usually forgot to do this until some glitch happened; restarting always fixed it. Mostly things just sounded dull after a while but came back after a power recycle.
Thank you for that. But I’m not asking about changes in sound quality.
That has happened to me once. I don’t play SACDs very often so I can’t say if it is a recurring problem.
The player, of course, has no idea what kind of you’ve loaded. If SACD is set as the default, it tries to find an SACD layer. If it can’t find one in a reasonable amount time, it looks for a redbook layer. If it finds a redbook layer after failing to find an SACD layer, it assumes you’ve loaded a CD an goes about playing it.
A dirty lens or a failing laser will cause the SACD layer to not be found before the search timeout occurs. The condition will worsen with time and eventually no amount of reloading will work. You’ll likely find that single-layer SACDs will load correctly while hybrids will fail.
You might consider opening the case, opening the drive, and using a clean dry cotton swab to gently wipe the lens. This will likely improve the situation for a while. You can try a lens cleaning disc, but these tend to only clean a small portion of the center of the lens.
Good luck!
This is good information to know - however, there are likely other causes as well as this had happened to me intermittently with a brand new SACD and 2 month old PST.
