Ultragain Pro MIC2200 (Still Available)
Can be used as a home desk top, stand alone preamp.
When you want to warm up your sound, only a tube will do. The Behringer Ultragain Pro MIC2200 is just the ticket! It’s the ideal extension to your console, sampler, hard disk recording system, or DAT recorder. The extremely low-noise, high-end 2-channel mic/line preamp with its warm tube sound lends your most demanding instrumental and vocal recordings incredibly detailed resolution and musical warmth. Helpful supplementary functions like parametric EQ, phase reversal switch, phantom power, and independent level conversion make the Ultragain Pro an indispensable addition to your outboard gear.
Features
•Extremely low-noise, high-end, discrete microphone/line preamp
•Integrated high-quality 12AX7 vacuum tube
•Microphone input stages based on ultralow-noise 2SA1084 transistor pairs
•Extreme bandwidth from 2Hz to 300kHz
•Two additional high-end parametric EQs
•Independent level conversion from home to professional level (-10dBV/+4dBu)
•Super low-noise 4580 operational amplifiers
•Extremely flexible DI box function
•Soft mute +48V phantom power
•Fully sweepable, switchable high-pass filter (12dB/octave)
•Phase reverse button
•Precise twelve-segment output level display
•Servo-balanced, gold-plated XLR and 1/4" TRS connectors
•Professional-quality potentiometers and illuminated switches
•Manufactured under ISO 9000 certified management system
Specifications
•Bandwidth: 2Hz-30kHz
•Servo-balanced, gold-plated TRS and XLR I/O
•Twelve-segment LED level display
•Parametric EQ
Asking $50.00, shipping not included.
Asking $50.00 would be good for a desk top system to add tube warmth, or home recording studio.
