USB Noise for OTG/USB-B Cable to DS Jr
I ask this with the understanding that Paul Hates USB.
I am planning on using a dedicate DAP transport and the one I am going to use has an OTG output.
I assume the ONLY way I can connect this to a DS Jr. is through a USB but understand it will have issues in SQ.
Do I have any other options getting this to one of the other inputs?
If not is there a cheap alternative by using some sort of filter o the USB?
The reason I am not wanting to use wifi is because of prior issues Ive had doing that.
Thank you in advance.
T
