HI All,
I have read that if you use Roon through the bridge 2 input on the DSJ you should see the track name of the song. With mine it shows for a second or so then switches to the File info PCM 44.1 etc. Is there a way to make the track info permanent? Bridge FW says it is up to date by the way.
Thanks
