What is the latest Nuwave Phono Converter Firmware?
Hi All,
The PS Audio Download page for firmware is very confusing to say the least. No description, information, date etc with not a standard naming convention. Some are called usb install, another is just referenced as update.
Anyone know what the latest firmware for the phono converter is?
thanks
Agreed: it is a bit of a mess. The latest firmware is NPC .54 USB Install.
You’ll get a file called 11-066-11-X-FMC-15.zip. Unzip it and copy to the root of a blank thumb drive, turn the NPC off, insert the drive in the USB port on the back of the NPC, and turn the power back on. The blue PSA logo will flash for a few minutes and then the screen will display a messing about updating for another minute or two. When it’s done, your status screen should indicate that main is 0.54.
Good luck! -Pb
Peanut Butter said Agreed: it is a bit of a mess. The latest firmware is NPC .54 USB Install.
Good luck! -Pb
Great! Thanks for answering my next question which was what value should I reference on the screen!
