Which is it?
#1
When I first sit down to listen to music, and push play, within the first 15 seconds my volume decrease’s a few db’s. What is causing that, my pre-amp, (Krell S-1000) my PWD, or JRivers? It drives me nuts!!
#2
My guess would be jrmc.
What are you using to control it?
#3
Just using straight jrmc, if that’s what you mean?
#4
There is a max vol setting in jrmc. Try setting it to 100%.
#5
There is also a volume leveling feature as well. It too has a few settings.
Al
#6
I figured it out. It was the encoder setting on jrmc. I now have it set to "uncompressed, and, wow, what a difference!
#7
Sounds like you were probably streaming in mp3. That’s easy to do by mistake in JRMC. Glad you figured it out.
#8
Nope…wav
#9
Didn’t know you could stream compressed wav. In any event, the JRiver settings can be a pain.
#10
They are a major pain. Even though I think I do understand most of the settings , I still get screwed how they effect each other.
Al
