Hi all,
Which sample rate should I select in the Advanced tab for the Sprout driver on Windows? It’s currently set at 44.1Khz. Should I even change that?
Thanks.
Hi all,
Thanks.
If you’re just playing CDs that’s fine, though hopefully you’ll want to have a program that auto selects the proper sample rate should it change.
