Yes, I realize that. It’s not the same thing, but at least one of those “pitch” devices serves an actual purpose. The other, just a toy.
Yes, that is something I would like to know too. What does the retuner do, if the original tuning was not 440 Hz? But, let’s say 415 Hz? What does it do with music that is not in equal temperament at all?
Hence why it’s best to leave well enough alone and allow the music to be played back as intended.
In the 432 EVO, you can set the base frequency to whatever the what the music was originally tuned. So, if originally tuned to A=444Hz, you set that as the base frequency. The “Target Frequency” is what you want to retune the music to (i.e. 432Hz, 430.5Hz, etc).
Didn’t get as much time to run through my tunes as expected. Will pick it up again on Sunday.
This makes sense, but it assumes the user knows the base/original frequency of the recording. Most people cannot sing in tune, let alone hear an alternate tuning.
The system could be designed to determine the original tuning given enough input.
Like filters, multi-wave, etc. it does not really matter of course; just use what sounds best to you.
Provoking thought. I’ll pass this idea on to Frederic the owner.
How did this ever end for you? Is it a positive thing or just one more thing you know who doesn’t need?
The server is an amazing piece of gear. It is in no way shape or form, going anywhere. Ive had it for several months and appreciate its contributions to my system. I’ve listened a ton 440Hz vs 432Hz and more recently, 432Hz vs 430.5Hz. The latter comparison is more similar than different and based on what I have heard, I am not convinced I could perceive the difference between those two frequencies 100% of the time.
HI Jeffo, would you encourage anybody to maybe go for the cheapest version (EUR 1,000 right?) if we happened to be in Benelux anytime soon?
I mean for the purpose of trying 432 first hand in one’s own system. Or would you say ‘better go for the highest upon the EVO product line you can financially cope with’ instead? Maybe even one to rival PSA’s Octave when it comes out.
Cheers
Hi @efete
Sorry, missed this post. That is an interesting question you pose. The good thing is, there is a great upgrade path within 432EVO as they give the customer 100% credit for trading in their product toward the higher model. So, that is a strong argument toward entry level as the first step.
However, there are distinct differences in the lineup, just like with most all hardware companies and the products they offer. There is a chance you may not like the entry level model but would be happy with a model further up the chain.
I had the “High End” (yes that is the name) model initially and then upgraded to the AEON which was worth the cost.
If you want to experience 432Hz and that is the draw, the entry model seems a good route to take.
I fully agree with you and everything plays wonderfully through my 432Evo Aeon!
You forgot to mention that the Aeon is also a bitperfect ripper and have 4 or more TB inside for storage!
One thing; I only have two separate power supplies… Do you have a picture of how you connects three? Maybe there is an upgrade for me to do?
Best regards Toby, Sweden
Thanks JoA, this does make sense. I might go for the most affordable version, see whether 432 ‘is for me’ then try to upgrade. And if it’s not or the Octave leaves all of us in awe -it could well do just that- then I’d make the bigger investment then sell the affordable Evo.
Regretfully a few weeks ago I decided to part ways with my wife, financially supporting 2 houses is a considerable hit , so I don’t think I could keep everything or have 3 systems as I would then have to eat rice and noodles for a year he-he.
Many thanks for your reply mate.
Yes, bitperfect capable it is! And the ripping function could not be easier. I have boxes of CDs I need to rip and don’t fear the chore with how simple it is. Insert CD, wait about 2-3 mins for it to automatically do its thing, then remove it once it pops out of the slot.
As far as the three separate power supplies, what I did was have a custom cable from Ghent Audio made that connects the USB Superclock card’s power input connection to the back fo the server case where I installed a barrel plug input, similar to the one for the server PCB power input. You just need to drill the appropriately sized hole for the input jack.
Now I run (3) separate Sbooster MKII power supplies on my Aeon just like the Master model.
Here is the cable description I ordered from Ghent and the price I paid. This cable has everything you need. Just need to make the hole.
Great tips for upgrades, Jeff! Thanks!
Which voltage is the Sbooster for this application?
SOtM USB Card: 9V
SOtM Superclock Card: 9V
Server PCB Board: 12V
Thanks !
Hi again! I am not that competent in electronics so…
- can you take some pictures of your connection, both inside to the USB card and of the external connection?
And I am curious; what improvements did the Usb connection to Sbooster do if you can describe a little?
Sorry to ask so much but you are the only source of this
Best regards, Toby
Would anyone try to describe how lowering the pitch by algorithm a couple of percent affects impulse noise, like a drumhead hit, or the white noise of applause in a live performance?
I’m betting that no algorithm can successfully modify those parts of the music without ill effects on the sound.
