Frode said My Audiobyte Hydra-Z USB converter arrives tomorrow.The point with this device is to feed it from the Aries USB, converting the stream to I2s and hook it up to the DS I2s input. The Hydra is powered via the Aries USB port.
My HDMI cable is Wireworld Platinum 2m.
The Hydra can support up to DSD512 natively on its I2s port, however the DS will convert this to DoP internally, nevertheless.
According to Ted there is a good chance that this might improve the SQ opposed to direct USB connection, however we will know this after it has settled in my system for a while. I will also look out for lock-on pops and latency issues.
My hope is that this solution will be a giant killer!
I would love to hear your review of the Hydra-Z … as I am in the process of getting one. Except I will be feeding it via a Mac Mini. Doesn’t the Hydra-Z come with its own power supply?
