I’m now using my HD800-S balanced silver plated twisted pair cables (they come with the headphones) - wow.
I’ve never used balanced interconnects in my HiFi setup or headphones setup - ever. So this is a first.
And now I have balanced connections from the DS right through to my headphones (via the Oppo HA-1)
I’m definitely keeping the HA-1 @tedsmith - thanks for the tip
This is phenomenal.
Using the HA-1’s 4 pin XLR headphone output keeps the SNR super high right through to the headphones and the resulting clarity and black backgrounds and natural sounding smoothness is unreal.
I’m using the DS’s -20dB attenuator and using the HA-1 on HIGH gain. Using the 4 pin XLR headphone output, I’m using the HA-1 at around 12 o’clock on the volume knob, so according to Oppo I shouldn’t have any channel imbalance issues at that volume knob position.
I tried using the DS high gain setting and using the HA-1 low gain setting, but I end up at 9-10 o’clock on the volume knob position. I’d rather keep it above 10 o’clock as per Oppo recommendation. I definitely don’t want to introduce any more components to the chain now (in line XLR attenuators) so I’m happy to leave it as is.
I keep learning that you don’t realise you have noise in your system until you peel back each layer of noise.
And Huron is even lower noise !? wow
This chain of Bridge II & Roon > DS > balanced XLR cables > Class A HA-1 headphone amp > balanced headphone connection, really let’s me hear the music produced by the DS in un-adulterated form - and I really like it
Another major lesson I’ve learnt here.
I previously used a Chord Mojo DAC/amp to drive my Sennheiser HD800-S cans. On paper it should have no issues driving 300 ohm cans and it didn’t have any issues.
But now my cans are powered by a beast of a headphone amp in the HA-1, oh my goodness, I now know what HD800-S owners are saying when they say these cans really do go up another level when there’s more power on tap.
Here are the HA-1 headphone 4 pin XLR output power specs below - oh yeh !
I’m seriously hearing things I’ve never heard before - and that was with a pretty decent HiFi setup which already included the DS. Wow
| Maximum Output Power (Per Channel) |
Into 600 Ohm |
2400 mW |
| Into 32 Ohm |
3000 mW |
| Rated Output Power
(Per Channel) |
Into 600 Ohm |
800 mW |
| Into 32 Ohm |
2000 mW |
