Do "ethernet over power" devices work with high end audio products?
I just got Netgear Orbi and it’s great! Fairly easy to set up and the Ethernet connection is solid from the satellite. The SQ streaming to my Mac Mini with Room is excellent also. Recommended.
I’ve used Eero mesh system for streaming audio wirelessly for components that require LAN connection (by hardwiring the audio components to the gigabit port). It works well and the network is very stable. Be sure to purchase the Eero Pro (has the LAN/WAN port). I live in a old, vertical house with thick walls and major seismic upgrades (e.g. lots of steel). It’s probably as challenging an environment as you can imagine for Wi-Fi and the Eeros work well. I believe their theoretical bandwidth is about 600Mbs but with backhauling it is substantially lower. I get between 90Mbs minimum and 300Mbs max throughout my house. System is super easy to install and had good app that allows you to net-nanny, provide guest network. It is not cheap, and there are systems out there that are said to be faster.
Welcome, Richard!
