I am currently streaming via Wi-Fi.It sounds very good but I suspect I am missing out on better sq quality. We have super fast reliable fiber optic to our home. Unfortunately, connecting my Innuos streamer to Ethernet and then to the router/modem means almost an impossible logistical journey. We have existing in wall coxial cable that we don’t use and I was told that setting up a MOCA system I can bypass the wiring challenge. Has anyone had experienced with a MOCA system to connect the Innuos and increase data delivery speeds, etc. ?
I used it about 10 years ago when I had a larger house - I remember I was able to get my full 150Mbps b/w with the moca gear installed all the way in the barn where I could rnot each with WiFi - I would say it worked well and worth a try if the gear is available
I’m using MoCa now. Just had to change a setting in the cable modem and hook up a modem device to an active cable outlet. I get just as good speed as with Ethernet. No problems streaming audio or video .It’s stable. You can add Ethernet switch port so you connect one to a streamer/ dac and another to tv/ etc.
The MoCa adapter itself could very well be a noisy device, but there are devices out there to isolate prior to feeding your dac. I don’t know if they better sq or not.
