Lunch with Paul & Darren - The importance of feedback in audio
I think one of the major drawbacks with very large amounts of negative feedback in any analog amplifier be it a line stage, phono pre or power amplifier is that you introduce large frequency-dependent phase shift in the signal within the audible band (especially at the upper frequency range). This likely causes a less satisfying musical result in terms of coherence or time alignment of the entire frequency spectrum.
This also helps explain why you want a very high bandwidth amplifier to avoid these phase shift vs. frequency issues. Upper cutoff well above 20kHz for example.
And, regarding TIM (Transient Intermodulation Distortion) this reply was most helpful and aimed at audio specific circuit design:
