This is a long shot, but I’ll see if you guys have any ideas on this…
Swapped out my Topping D50 DAC (which I’m going to use in a different room), and put in a Topping D70. Cool thing about the D70 is that it can utilize the Matrix’s I2S output. (Plus it has balanced XLR outputs.)
Anyway, hooked it up with a Pangea SE HDMI/I2S cable, but not getting any output from the DAC. The DAC sees the signal from the Matrix, though. (The DAC’s screen lets me know this.)
I tested with a different HDMI cable, too. No difference.
I’ve tried moving the dip switches around on the bottom of the Matrix, but nothing. (Totally thought this would be the answer!) Thought it might be a DSD vs PCM thing. FWIW, I’m not converting to DSD.
I tested the other connections from the Matrix to the D70, and they work just fine. AES/EBU, Optical, Coax. No problem. Sounds great, too. But the DAC doesn’t output anything when I2S is used.
I am also using HQPlayer Software, and I tested removing that from the equation. Makes no difference.
AES/EBU is what I’ll use if I can’t get I2S to work, and I’m sure it will sound just as good on my system, but anyone have any ideas? What am I not seeing?
Note: D70 was bought used. Everything is minty though. All original packaging, remote, cables, etc… Looks brand new. I’ll touch base with the seller, but thought I’d check here first since y’all are X-SPIDF savants!
