Sent $300.
Got it, thanks!
I deleted the personal info in the above posts to avoid the crawlers. It looks like the two of you are all set. If not, I suggest going to PMs.
If I can help just let me know!
Wait! I’ll give you $375!!!
Too late Al!
Thank you Sir!
@aangen probably has 4 Pardo’s in a closet at home already.
Probably buried beneath his propane tank!
Before I spend an hour fighting the spiders and the dust in the storage space to dig it out, any thoughts on how an old squeezebox touch will sound pushed through a matrix?
My guess is it will sound pretty good.
Happy Cake Day!
Axshully I donuts.
The best power supply I have is my Keces P8. Second place is my Sboosters. Third place my Small Green Computer supplies.
I also have two Uptone Audio supplies but one died.
I currently have more DACs than power supplies.
You have to do some sort of trick to enable the USB port to be an output. I never bothered to learn that trick with mine but many did. I suppose you could use the regular digital outs but I recall reading it sounded better through the USB port.
I think it’s worth doing myself. (Testing it through the Matrix)
Happy Anniversary!
My second Sbooster is arriving tomorrow. If you didn’t speak so highly of them I’m not sure if I would of discovered them. So thank you for pointing me in the right direction!
Oh really? You are most welcome. I like mine quite a bit. There are folks here who didn’t stop at Sboosters and found others they like better. I am curious, but not curious enough to order one.
I hope it takes as good care of you as they do me!
I have one on my Matrix Spdif and the second 19v will be for my Nucleus. The Sbooster for the money seems like a bargain compared to some of the other well reviewed power supplies on this forum.
Naw just the equivalent of a King’s Harem each different with its own unique attributes till he finds a new special beauty.
I recall it was the Enhanced Digital Output plugin. It’s been many years, but I think it was fairly easy to implement. Will give it a go, see how it sounds.
I recall being very very fond of my Squeezebox Touch (2). Then I got a Transporter. I had troubles with the Transporter so I gave it to the guy who taught me to buy expensive cables. I doubt he ever powered it up. Sad as there was a time when the Transporter was the most desirable object.
Those developers really had it down with their server software, particularly with gapless. I remember Paul and his boys at PS Audio struggled for what seemed like years to get gapless implemented with bridge I. Never happened until bridge II
The newest driver is v.5.0.0.
Works on Win10.
V5.0.0 (December 04, 2020)
New: support for Windows 10 (2009/20H2)
Fix: “ExposeToAsio” registry value in VirtualChannelProfiles
New: API version 5.7, some API functions added
New: several registry parameters added
New: WDM sound device profile switching
New: hardware channels can be hidden now
New: USB audio float format support
New: ASIO DLL now supports “AsioHide” parameter
’ New: ASIO future extension allows to get access to hidden channels
Chg: reduced default StreamingBufferMaxDuration from 4ms to 1ms
Chg: documentation
