I may have mentioned this before, way too many posts to find mine.
I don’t know if this is possible, but I think an ideal solution if we are stuck with MQA, which does sound better partially unfolded, than the 16/44 files on Tidal. Would be for Meridian to make a box, could be the same case as the Explorer DAC, that would do all the MAQ processing and then output it as the fully unfolded digital signal. Design it so it just passes non MQA untouched, maybe have it convert from USB to spdif optical or coax.
If that would be possible we could then send it to our DAC of choice. I think if they can sell the Explorer for, what is it now? $199 or $299, they would sell lots of them at that price. I would like to get the full MQA, but I would rather stick with partial decoding than change DACs. And if I do upgrade my DAC it would be about 95% certainty that it would be a Directstream, and that is not going to become a MQA DAC.
By doing the partial unfold in Tidal’s software, I think a total software/firmware solution is possible. The have back pedaled on both their claim of having to know which ADC was used, when they started doing batch encoding, and that they needed to have access to each brand of DAC with the partial unfold, so I am suspect about the final steps.
For streaming, I don’t see that going away, so we are going to have to live with MQA if we want to get the most out of Tidal. And finally, Tidal is no longer putting all Master files under What’s New. They have added “M” in a box next to the titles like they do with the “E” box for explicit content.
I just listened to Lou Reed’s “Magic And Loss” partially unfolded, it sounded very good. I can’t say I have ever heard it in hi-rez as a comparison. I find Tidal’s 16/44 very inconsistent, some good, others that can’t compete with a CD played on the PWT. They only post provenance when it is included in the titles. Like with the Jethro Tull files that state they were remastered by (I forget the guy’s name, and I have a 75lb dog in my lap, so I can’t get up to go look). But you get the idea.
